White 500L
Hi my names Joe I drive a fiat 500L. Looking for advice on some of my problems with the car
Where do I start. The eml is on and the car won’t rev past 2500rpm. I’m getting fault code P2563 (Turbocharger boost control position sensor A high) I’ve replaced both MAP and MAF sensors. The thing is if I drive with my code reader plugged in and continuously erase the code the car drives and revs fine a turbo kicks in properly. Any ideas as to what’s wrong?Hi and welcome
Semi.auto gearbox is a likely niggle..
What do you wish to know??
Yeah that’s the engine. I’ve tried searching the code and can’t really find any solutions that’s why I’m asking if anyone has been able to fix it.Im guessing its a 1248 multijet
Mine were pre.DPF.. so simpler..
But if you SEARCH that code on here you should find LOTS of info
This little diesel is used in millions of cars
Don’t know what you mean by figures?Posts from @ryantech
Seem to suggest it can be DPF related..
What figures are you getting for oil and soot?
