Hey,
can anyone tell me the factory percentage of the throttle body when idle?
Sometimes my engine is stalling when pressing the clutch from normal revs.
In MES the idle percentage is 0% when I'm off the pedal. Shouldn't it be 2-3% ?
When I press the pedal the data makes sense without any jumps.
In the photo i've marked the moment the engine is stalling.
It only happens when the engine is warm, but the lambda data is fine. Checked with MES and an additional lambda gauge in the cockpit.
New parts:
Vacuum hoses
Lambda sensor
Variator spring
Idle valve (with battery off/ on and let it idle from cold to warm)
Cleaned the mass air flow sensor
Coolant temp sensor
Spark plugs
Timing belt (timing is set correct)
Cleaned and tested the PCV Valve
Tested with 2 fuel cut off switches and 2 fuel pumps
Cheers Frank
New parts:
Vacuum hoses
Lambda sensor
Variator spring
Coolant temp sensor
Spark plugs
Cheers Frank
- Year
- 2000
