- Joined
- Oct 1, 2008
- Messages
- 184
- Points
- 33
Before I begin, I have read the threads about swapping red and yellow wires around but think my problem may be different.
Bought Pioneer DEH-P800BT (sold the kd-axv33) and tried to plug it in today but I could not get it to work.
First thing that is confusing is that the Yellow 12v constant supply wire has a red tip, and the connector is not like the other ones. It is flat and sort of spatula shaped. I have added a pic so you can see what I mean.
I bought the stereo off ebay and not sure if the previous owner has added the red bit on to the yellow cable or if it is meant to be like that? Should just be a normal bullet connector?
As also can be seen in the pic, the actual red wire is connected to the yellow wire. Does this need to be swapped?!
Cheers for the help
Cheers for the help
