Bolinhas899sx
- Joined
- Feb 23, 2021
- Messages
- 43
- Points
- 13
Hi Good People.
So I'm doing a complete and a series of flushes on the coolant system on my cinquecento SX 1998 and change the cooling tank, radiator hoses, Water pump, Thermostat and radiator, cause the car looses water and its arround 20y and the previous owner for this last couple of years decided to put tap water on the system as it kept leaking and loosing water.
So the tank and all the water is rusty red as seen on photos (plus the Thermostat all calcified)
Source of leak? Been around and arround, cleaned all the exterior engine and pipes.. Been for few rides and no apparent source of leak.. Neither white smoke or any thing like that, so don't believe is burning water.
So my question is the order in what I do this:
Drain the coolant/rusty water - change the coolant thank and then do the flushes (plus Wynns radiator flush) with the old parts in (radiator, water pump, Thermostat) in and then when the system is clean replace with the new parts?
Or do I drain the coolant - new coolant thank - replace the parts and then do the flushes?
My doughts are if I do the flushes with the old parts in I'm afraid of lodging rusty bits from the old parts into the engine coolant compartment..
But if I do flushes with the new parts.. to lodge the rusty bits that might be in the engine into the new parts..
What you guys think? ?
Thank you everyone.
Thank you everyone.
