Styling help painting brake calipers
oriongreypunto
Saltcoats (West Scotland)
hey
got some red brake caliper paint for free with my alloys and thought i would paint my calipers , is it just a matter or removing the tyre then caliper from the disk and painting or am i missing something ?
cheers
oriongreypunto
charlieboy
east mids. derby.
easy as dude! (y)
-mask off the brake lines and bleed nipple as you dont want paint on them.
-rub down with a wire brush.
-using brake cleaner (aerosol type) soak the calliper and dry off with a rag
-then allow to dry completey.
-then apply the paint (not too thickly or itll run)
*should be 30 mins to dry between coats*
apply another coat and let it dry
after its dried leave it for bout 3hrs to harden off before you put the wheel back on.
then leave for a further 24hrs to let it harden off properly......jobs a gud'n :tuhmb:
*this is how i did mine**
charlie
ps - i know theres paint on the pin holding the pads in but its cleaned now :)
OP
OP
O
oriongreypunto
hi
wow thanks for the detailed reply (y)
that helped alot :D , your calipers look very nice , just how i want mine.
did you remove the calipers from the disk when you were painting or leave them on ? i will be using paint instead of spray paint so i should be able to leave them on ?
cheers
oriongreypunto
charlieboy
east mids. derby.
oriongreypunto said:
hi
cheers
oriongreypunto
left them on the car, its easier to tske them off though.
charlie
