H
hgt_20v
Went to start my car this afternoon for the first time since sunday and when I pushed the clutch pedal down it was very spongey, and could not select gear with the engine running.
So had a look under the pedals and discovered that the car has a hydraulic clutch (news to me!)
So I checked the brake fluid level and it was seriously low. Topped it back up and pumped the clutch pedal for about 2 mins and now i've got a normal clutch pedal back again.
Am I right in thinking that the brake fluid is also shared by the clutch?
is there any reason why it's used the fluid in the resevoir? when I put the wheels on the other day I did notice that the rear pads are right down and need urgently replacing, could that be why there is lack of fluid up front?
As luck would have it i'm fitting new brakes this week (with the help of a mechanic freind) and will be doing the front and rear discs & pads. Should this cure it? There is no signs of leaks anywhere that I can see on the floor under the car anywhere, near the reservoir under the engine bay, and on the calipers anywhere.
Any help would be much appreciated.
