Technical help gear selector unit in gearbox
marzon
talking Marea weekend, 1997 2,4 TDS 125, manual 5 speed gearbox
I did a clutch change, according to manual I took out the gear selection unit from the gearbox prior to removing the gearbox from the engine, when I started to build her back up, I accidently put in the gear change assembly in the wrong position, now I can't get it back uot, it is stuck in the gearbox. I can't move the stick when cables connected, there's little play in the assembly, I can get it up to the point the bit with the O-ring cleares, bu no further than that.
can't look inside, can jerk a little with the assembly, but it doesn't come out again.
WHAT NOW ??
I certainly hope someone here can help on this issue....
