Help fitting arches
Help fitting arches
A
abbi
hi
im looking for some help i want to put some arches on my bravo but got to be easy to fit any ideas let me know thx
***Title Added***
As far as I now, no arches will fit correctly unless modified, so if you're looking for something easy... it won't happen.
The best ones are off a Suzuki Jimny, but also need trimming and modding.. they look good once fitted though..
Generally anything in the way of body modifications, will take a bit of time (and sometimes skill) to fit the Bravo/a... there's not much out there.
As above. Arches on the Bravo are custom only.
Peugeot 206 arches also fit the Bravo with some tweaking but again its not a simple clip on job.
The Bravo Stays!!!
thx ill give the 206 arches ago had a go at the jimny not very good way way to much needed i spent to much on it already just wanted to finish it off really spent about 4 k on the car at the min thx for ur help
re
i always thought some arches off somethign liek ford transit connect/isuzu rodeo would look good and not be too hard?
lol, trimming is an understatement,lol, mine had to take quite alot of modifying, and then arch extensions for the front and rear bumpers also had to be made!
The easiest ones so ive heard are 206 ones, but they dont stick out very far!
i had mine custom fitted.
it took quite a fair bit of cutting and fitting and finally finish off with some fair bit of fibre work and cement.
final job was great.
3
1K
Tommy K
T
M
4
373
M
K
5
934
Tommy K
T
M
278
malish
M
