Hi
I've got a problem with my 55 plate 1.2 petrol Punto. It's only done 18k miles
Until a few weeks ago the car ran perfectly and the engine was very quiet and smooth.
Then one day when I started the car the engine was rough and missfiring - the engine management light came on and the car had very little power. After leaving for a while and restarting the car ran fine - however the engine management light stayed on for a few days before clearing.
A couple of weeks ago the problem came back - engine management light on - really rough / juddery engine / low power. I replaced the HT leads however the problem remained. On starting the car, the revs would drop right down to 900 then jump back up a little before going back down to around 750 where it sat in idle.
I put the car in the garage I use - the lad said that the coil pack was faulty - he replaced both coil packs using spares from the local breakers - at the same time he also replaced the plugs.
When I got the car back I noticed that the engine didn't sound as smooth as it had done before, however the problem seemed to have gone.
After a couple of days, the same problem occured. Engine management light back on - heavy judder from the engine and loss of power. The car went back into the same garage - he said that it must have been a faulty coil pack that he got from the breakers - so he got another and replaced it.
Again - when I got the car back it was fine - a lot smoother and fairly quiet engine. However I noticed that when I started the car it did make a bit of a rough noise as it fired. Also when idling and driving every now and then I could feel a slight blip from the engine like the power dropping for a split second. When accelerating I'd sometimes get a little hesitation but then it would run fine.
That was a week ago - today the car has got the same problem - engine management light on - low power and judder when idle. Increasing the revs increases the intensity of the judder. I'm going to have to take it back to the garage again - but can't believe it's the coil pack again.
Lost for ideas - had a quick browse on the web and I'm wondering whether it could be the ECU or something with the air mass flow sensor.
Any ideas?
Any ideas?
