Sorry yes all 3 lol I know that one is a abs sensor but the others am not sure at allTo which error are you referring to? All three? or one in particular?
Be a bit more forthcoming with the information
Non really what it is I bought the car for 150 pound the lad had it payed 1600 for it 4 month ago I don't know what he was doing but he didn't tighten the front left wheel up n when for a drive wheels come off messed the wing up I have replaced the wing as that was fooked but every thing else seems sound the but when the you start the car it says abs esp hillholder unavailable I have drove the car on to the tow truck when bought it as has no mot but it didn't feel like any thing was wrong other then a bookeld wheel the lad said he don't know why the lights come on as they didn't come on until he had got the car home n left it for a hour or soError codes are only 1/2 the story, what symptoms are you experiencing which caused you to want to read the codes?
Buying a car after hearing a story like that only makes sense if you want to break it and sell it for parts otherwise you've signed up for an endless headache.
That was my point the engine n gearbox n every thing sounds mint no horrible nocks or bangs I know that one injectors is leaking but that's easy to fix I know one of the problems is low voltage caused by the battery but the other am not sure aboutso what if wheel fell off, doesnt mean car is scrap
The car is to good to brake it don't say it's failed just unavailable so it's nothing that can't be sorted am not bothered if it cost me 300 to fix it for what I have payed for it its worth the moneyBuying a car after hearing a story like that only makes sense if you want to break it and sell it for parts otherwise you've signed up for an endless headache.
No was left It's boggled my mind why the right is showing up not the left n am gunner take that off tomorrow n clean it up n have bin reading up about that on here n other forums as well that it may just need a cleanWas it the right wheel that fell off?
Have you looked at the inlet throttle body?
Might just need a good clean and throttle relearn ..
As for the u body computer node fault it got an after market head unit by any chance?
Gunner have a go at that I bought the multiecuscan like I said I was so I can have a check all time will get back to you n let you know if sort it thanks for your help [emoji106]My evo threw it up but everything worked... Blue and me system working?
Worth resetting and trying again a week later and see if it comes back
Will doCheck condition of wire and plug in arch
