HELP - Alarm led stays on deactivation
J
james p
its a std fiat alarm on a 1.8 bravo.
checked the bonnet and boot switches.
Help req plz.
james
mine does this occasionally its a punto though.
might be the same alarm.
i found that when you disconnect the battery 15-20 minutes or so, the light stops doing this.
maybe worth a try.
did you mean it comes on when you turn the ignition on?
mine did.
Re: Re: HELP - Alarm led stays on deactivation
Could it be that its just the LED that's gone, set the alarm then open the boot.
Daz
Re: Re: Re: HELP - Alarm led stays on deactivation
it stays on till the key is inserted and turned to read the keycode.
j
Re: Re: Re: Re: HELP - Alarm led stays on deactivation
Mines doing the same. My understanding is that this means that your alarm has been tripped at some time and that disconnecting the battery for a while will reset it. Not tried yet as it works and I cant be arsed.
Shabash!
