Help! I've checked other threads but can't find a similar problem. I recently changed the heater blower in my (non climate control/non ac) Panda 1.2 dynamic. The old one had stopped working on all speeds and helpful threads found herein did the trick. All good I thought. Heater fan blower works fine again (well, I can hear it getting stronger as I move the switch up through the settings) but now the flow of air through all the vents is tiny and doesn't blow stronger as I turn the power up. Hmmm, confused am I. Logic says I may have knocked the direction flaps (!?) out of kilter (if that is possible) so that now nothing blows from any grilles (windscreen, face, feet, etc.) no matter the speed, heat or air direction settings.
Does anyone have an inkling as to what I should fiddle with??
