hi just got jtd active the problem i have is blower motor works fine all directional vents can be selected by the dial but no air or very very little comes out ? any ideas
hi thanks for all replys my stilo is the jtd active 52 plate without a/c it blows cold and hot when turn temp dial wheather engine col or hot i can select any direction screen,floor, face fan runs at all 4 speeds but still get no air pressure through the vents hope that explains my problem a little better do appreciate all your replys so keep them coming because fiat want to remove dash to just look at it at a est cost of £500-£700 thankslittle becky said:i have the JTD and mine takes about 4 miles maybe abit less to heat up. Ive noticed that quite a few fiat desils take abita time to warm up tho![]()
keith price said:hi just got jtd active the problem i have is blower motor works fine all directional vents can be selected by the dial but no air or very very little comes out ? any ideas![]()
Deckchair5 said:Well done you!![]()
I notice the Stilo has pollen filter change on the schedules for absolutely every service interval (charged spearately to the customer). So where is it on your Stilo, how much is it and did you find it easy to change?
Ruairidh Dunford said:I managed to remove the wipers and the plastic cover over the intake for the fan. There was a plastic frame around the intake, which looked as though it might be where the pollen filter should be.
The circular fan inside appeared free and when switched on you could feel air being sucked in, nothing very impressive though, is this just an inherent fault in these cars? Can anyone shed any light onto why the flow is so weak?
Cheers Ruairidh
