Thanks for the feedback guys, found out that the Dipped and Main beams are both H1 fittings soooo unfortunately this rules out the Philps X-tremes sooo will have to go with the Osram Nightbreakers which are meant to be nearly as good!?
Also just incase anyones wondering the Sidelights for the Bravo are W5W, and the front fogs are H11
C62
Changing bulbs on Fiats is like a Krypton Factor Physical Challenge!!
I've used Osram Nightbreakers and Osram Cool Blue sidelights and I am very happy- nice and white rather than yellow.
Isn't the Cool Blue a bit bluish? Are they the same white as Nightbrakers?
I find them the same white output at the Nightbreakers- indeed the sidelight bulb is the same blue colour as the tip of the nightbreakers.
The cool blues certainly do not put out a noticeable blue light unlike some other sidelight bulbs.
Sidelights changing is piece of cake. The main beam behind the window washer fluid bottle could be a challenge indeed.
