Technical Head Gasket & ECU
If you disconnect it from the batt for long enough it will reset it self anyway.
If you change the headgasket then I would assume you do as it is a self learning ecu (cheaper than prefixed ones apparently) so will get confused as the compression ratio will have changed I reckon.
Consult haynes manual for how to reset it properly, if you need to atall.
