Technical Handbrake cable rubber boots
Pretty common failing that. Doubt they're available as a separate replacement part. Better to just smother the ends of the cables with copper grease to keep the elements out...
Many thanks for the links Suicide_Jockey. Any idea how to unhook the cables so the new boots can be slid on?
Slacken the handbrake cable adjusting nut, then unhook the ends of the cable from the lever on the rear calipers. The adjuster is under a lift up panel in the carpet behind the middle of the front seats.
