very easy mate. make sure it is the hand brake cables first. there are two cables 1 for each wheel. take of the handbrake cover and loosen the cables which you will see. next hoist the car up and at the drum you will see the cable were it is attached to the brake, detach this. im pretty sure the cable runs under the heat shield of the exhaust so take out the dew boilts and move it. the cable should come straight out.
