General Guys ive got new gearbox oil leaking out my damaged gearbox exit plug.
Fiat are absolutely useless, where can i get a new gearbox oil exit plug, mine has been previously damaged and i need a new one. Is there anything at halfords to anyones knowledge that will do the trick?
Or can i indeed use the undamaged gearbox inlet plug? its a bit shorter in length but would it work?
Gutted loosing all my new oil!!:(
Damien.
FIAT do have these parts, you just need to give them part numbers. Are we talking the drain plug for the main box of a pre-91 4x4?
If so, the number is 7751645 - £3.73. It's magnetic, so worth getting proper one.
Thanks Lewey
Went to fiat in hove today guy was friendly but had no clue to the part number etc.
My car is a 1990 sisley so that part number should be ok?
Dont know how i am going to get the old one out the head is split!!:(
Damien.
Cheers Lewey
Going to have another go tomorrow!! got a 14mm gona try and tap it in to try get a prise it out. Wish me luck. Maybe try and use the fill plug to plug the drain hole?:confused:
Damien.
Guys i finally got the damaged gearbox exit plug out!! Bonded a 12mm hex bit onto the plug with liquid metal adhesive and brute force!! what a feeling when the pig came loose!!
Pumped the recaptured oil back in again and job done.
So no more leaking and shiny new plug in its place bliss....:)
Damien.
You in Brighton purple haze?
