General Gunge under rocker cover - 903 OHV
CaptainTuba
West Wilts Panda Reserve
Wilts
Hi - just taken the rocker cover off Graham.:yuck: :yuck: :yuck:
I'm sure that this is as a result of a blocked breather tube, short jouneys and poor maintenance.:mad:
I've cleaned the rocker cover - but what is the best way to clean the rest of it?
First of all I'm going to take the rocker shaft off. The book says undo the bolts a bit a time. Porter says they are torqued to 39Nm (Rocker shaft pedestal nuts).
I'm worried that this oily gunge will cause problems - if it comes loose in chunks. I was going to use an oil treatment but now I'm not so sure.
What do you think folks? :confused:
C.T.
Nuova500
Czech It Out!
New Milton, United Kingdo
thats pretty usual for an OHV engine. Mine was similar but not as bad. TBH I would leave it well alone unless you remove the head and clean it thoroughly, like you say while you are cleaning it off a chunk could end up in an oilway.
carnut
C.T.
to be honest with you mate thats excessive engine wear you need to flush it with engine flush and re-fill it with engine oil and oil treat ment mate it should help to get rid of the gunge use a small wire brush before you flush it to loosen the gunge then flush it and it will clean it the re-fill it with oil and oil trteatment this will prevent further engine damage ok mate
Watford
That looks like a combination of poor quality engine oil, poor maintenance and short journeys. If it is that bad be careful of using engine flush as it could cause big chunks to come away and then block up oilways with expensive results.
You could try using some decent quality oil which will come with detergents to clean the engine. Give it a good long run as well and maybe change the oil earlier than usual. Don't forget the Italian tuning method - thrash the arse off it on the motorway for about an hour to get the engine nice and hot - that should clean out the cobwebs! :p
Nuova500
Czech It Out!
I honestly feel people are ove reacting here... the OHVs do gum up like this, you should see some old A series lumps that are happily running well worse than that. Whats the mileage btw? It could well be short journeys and poor quality oil, maybe its been run on mineal for a long time. Really I wouldnt use an engine flush, if a chunk gets lodged in an oilway youll be in trouble.
auto_blanco
Solihull
Having had Ford OHV engines plenty, this is common with OHV engines, and as the bits where the oil collects really are just ledges for it to settle on I would just leave it as is, clean the inside of the cover just to make sure any splash lubrication isnt affected and make sure rockers etc are clean enough but dont over react and put engine flushes in, they rarely do what they say on the tin.
OP
OP
CaptainTuba
CaptainTuba
Wilts
Separated at birth?
Gunge extracted from rocker cover and Panda Poo
OP
OP
CaptainTuba
CaptainTuba
Wilts
No more Panda poo.
I finally managed to get rid of the Panda poo :)
Just set the valve clearances today. The exhaust valves need much more adjustment than the inlets.
Neither Haynes nor Porter say if the valve clearances should be set hot or cold. Any ideas folks? :confused:
Also number 8 rocker is a little loose on the shaft - it can slide side to side a little. Will this cause a problem? :confused:
C.T.
