Grundig MCD-46
Grundig MCD-46
M
Mark
Just bought a Grundig MCD-46 for my Brava. To secure it in the boot, is it necessary to drill some holes and screw it down? I just want to check before I drill thru something!
Mark
mcd-46
Just bolt through the carpet and board and use the pads to stick to floor of the boot, job done.
i suspended mine from the parcel shelf, less likely to get hit by anything rolling about in the boot.
Took about 5 mins.
Re: Re: Grundig MCD-46
Just fitted one under the rear seats, there is already a cut out for it, all you need to do is trim the carpet..and it can't be seen easily unless you know where your looking
S
549
Stuart
S
K
4
239
Dark Lurker
G
7
346
K
J
3
294
Joske
J
