Grrrrrr Components
Grrrrrr Components
B
Bill
Hi all,
Finally installed my system at the weekend (by me I mean Danny installed and I watched) but we have a problem.
The sub is working beautifully but when I turn the system up, the component woofers struggle and crackle on the bass. They are amped and were working fine before when just running of the HU.
JVC HU
JBL 5.25 Comps
SPLX (Cough) 300W amp running the comps.
Any ideas where to start trouble shooting?
Bill
Turn the bass down going to the comps.
Its quite possible that they cant handle the bass amplified.
You need to high-pass the components, they don't like bass as much as the sub does.
There should be a high-pass filter on the amp, simply turn it on and you should be fine ;)
Daz
"Failure is not an option; it is bundled with the software" - William Gates
I need to learn how to type faster :(
Daz
The sub and the comp are running off two different amps, sorry should haver said that.
Danny said the amp running the comps doesn't have a high pass filter.
Can you buy high pass filters like you can for the bass filters?
Apologies for my lack of knowledge
u got ur level bar turnt up to hi and also check the switch thaty says for sub use isnt on
Smee
Smee the amp your on about is the amp that is he using to run his sub. the other shite splx one doesnt have that switch. Bill you **** **** off.
lol
you just wish it could sound like mine does.lol
soon it will sound exactly the same, just wait til i get a bit of cash
Daz
Many thanks for the response but my knowledge is not as vast as yours!!
Um... What is that?
Is it the filter?
PMSL, you bloody wish. mine will always be far superior to yours. as you know just keep reading your max power guide and you may get it to sound a bit above crap!lol
model number / name. might have a hi pass filter built in
Smee
You can get little things called bassblockers, they look like slightly large RCA adapters. Helfrauds used to sell them.
Put them in line with the RCAs to the SPLx amp.
T
4
492
scotty
S
T
142
T
L
2
171
Anonymous
A
