Hi everyone,
Today I had a bit of a nightmare with my 07 grande punto 1.2. Recently the car has been causing some problems with gear selection, specifically when the drivetrain is hot the gear selection becomes very stiff and the car refuses to go into gear. I suspect the clutch is due for a change but before I bit the bullet on that, I decided to try a few other things which I thought could help. I changed the gearbox oil, and bled the clutch hydraulics. These seemed to help but it did not fix the issue completely.
Today while having a look over, I noticed the slave cylinder is flexing on its mounts whenever it pushed on the clutch pedal, and I noticed that the bolts holding it down had become loose. Unfortunately, when i went to tighten them, one of the bolts sheared and half of it is stuck inside the threaded hole. No matter what I try it does not want to come out and it has driven me crazy. This brings me to my two requests from this post:
1) Does anybody have some wisdom on the gear problems and what could be causing them? Do i need a new clutch or is this slave cylinder the likely culprit. When removing the slave to get to the bolt holes it leaked a bunch of fluid on me too, i'm not sure if this is normal or it means the slave is on the way out.
2) Because of this sheared bolt being such a pain in the a**, I was wondering if i could get around it by replacing the entire bracket on which the slave cylinder, gearbox ground, linkages etc. sit on top of. I've attached some pictures of the bracket with what i think are the mounting points in yellow. I can't seem to find a part number or even an assembly diagram of this part of the gearbox case anywhere, and tbh I'm not even sure if this is something which can be replaced.
Any advise would be really appreciated )
-Vaid
-Vaid
- Model
- Grande Punto 1.2
- Year
- 2007
- Mileage
- 110000
