I have a problem with non working third brake light. Message appear in dashboard "- check brake lights and also another one that boot is open. After some investigation i found that some one make a mess with wires and for third light there is no wire at all! I use elearn I found correct wire (CN - orange/black) going to pin 18 of Body computer. Someone connect this wire to boot lock motor pin3. I disconnect from boot motor lock and make some test connecting 18w bulb to this wire and earth press pedal but light is not working. It is obvious that body computer is damaged! Is there a chance to disable this message - dtc off (and get a wire signal from left brake to third brake light) because everything is working ok except this 2 warning messages - aditional brake light and trunk open.
