grande punto 1.3 mulitjet engine light and no power at 3000rpm
welshy0007
The engine light came on and there was no usual power like the turbo kicking in at 3000rpm I took it to the garage who put it on a diagnostic. Came back error code p0069. They cleaned the egr valve with no change. They then put a new egr valve in. No change replaced the map sensor again with no results. They said its like finding a needle in a hay stack but its nit the turbo. Any ideas? Ive tried reving it to blow any muck out. Sometimes it will pull normally as I leave my house but when I brake at the end of the street it then looses the pull at 3000. The garage said after replacing the map sensor the code has gone but the light comes back on. And the priblem persists. Can anyone help to stop me spending a fortune. Cheers.
They may have changed the egr, but have they cleaned the gunk from the rest of the pipes, that happened with my egr, had it cleaned had loss of power, gunk had blocked the connecting pipes, cleaned them and all ok again.
