Technical Got my first puncture..to buy a new or repair
Hello
Got my first puncture today in my nice new continentals :'( only got them put on in January!
Any way, the puncture was caused by a rather large screw and im wondering whether or not it is worthwhile having it repaired professionally instead of buying a new conti tyre to match the other side
Any experiences with tyre repairs being good or bad i would like to hear your opinions
Ultimately i would like to salvage the tyre as its pretty much brand new
John
oldhammer
Busy rebuilding pand'a
manchester'ish'
as long as screw aint gone into sidewall,
you shouid be able to have it repaired.
best bet is get your local tyre fitter to have a look at it
OP
OP
gijohn2
I have a few tyre repair places local to me, so going to give them a ring to see how much it costs then take it down
Here is the bolt/screw
Faringdon, Oxfordshire UK
Punctures can only be repaired if they are within the centre three-quarters of the tread width, which yours is, so should repair fine. Outside that area, it is deemed too close to the sidewalls and flexing is likely to detach the inner patch.
The screw could be quite a big diameter as punctures go, but its head has prevented it penetrating too far, so hopefully ok. Get to a reputable tyre dealer and let them look inside. If the hole diameter is ok, and no noticeable damage to the tyre structure they can repair it and it will be fine.
Tyre repairs are controlled by law, and must be a mushroom type patch. The head of the mushroom covers the hole inside and the stem fills the hole to keep water out of the tyre structure. Do not use the DIY plugs linked to above, or anything similar, they will not meet regulations and more importantly may let go at speed.
Get it done properly and relax.
flisko
on my other car i hit the curb at like 50, tire poped on the sidewall- 1mm hole, everyone advised against repairing it
oldhammer
manchester'ish'
your lucky its only the tyre needed replacing. :confused:
50km or mph. ?
ihit a pot hole in a honda civic once at 45mph ish tyre blown up
almost destroyed front end of car.,
dave
Essex/Suffolk border
have a google for a measure and take it with you some places will say its outside of repairable area even if it isn't just to try and sell you a new tyre, if you have driven on it flat they (should) also refuse to repair it. but again some will try and say you have driven on it when you haven't if that happens tell them to fit spare on then go some where else.
It looks JUST in the repairable section to me - but a measure is best way only
personally i'd get it repaired, there is nothing wrong with a puncture repair as long as its within the centre 75% (ie not on the shoulder or sidewalls)
Since its a nearly new tyre - its daft throwing it away
ziggy
oldhammer
manchester'ish'
All sorted, repaired and new valve for £15 another place offered it for £12 but was further away
Here was the culprit
the bolt looks like a punto headlight retaining bolt.
or atleast ifound same/simalar bolt on punto ipulled front end off today.
OP
OP
gijohn2
Nah nothing like the ones that are holding my headlights in place, look similar though
I drove over it at a garden centre when taking my gf to work
