My gear lever sometimes misses the 3rd/4th gate
Acting on advice here I got the gear linkage kit and set about to replace the bushes.
1: However, the old bushes were very good, replaced before I bought it 60000km ago I would say. But I have replaced the bushes in the gear lever, and one other, the linkages are very firm now.
2: Is there a metal surround the goes over the rubber bush that is on the pivot rod and holds that rod just forward of where the gear lever goes through the floor. There is some movement in this rubber bush that I would like to eliminate.
3:What is the mechanism that keeps the gear lever in the 3/4 gate. My gear lever wants to go to the 1/2 gate all the time. This can cause problems finding 4th after being in 5th, and sometimes 3rd after being in 4th. By this I mean, if I try to push straight from 4th to 3rd it will not go through, to get it to go through you have to push forward and very slightly to the left.
If I could fix this 3rd issue the gear shifting would be very good.
