Technical gearbox
Technical gearbox
crazycraig
can anyone tell me if the gearbox from a punto 55 will fit a 75 :confused:
because the shaft in my box is really noisy :bang:
OP
OP
C
crazycraig
not sure mate thats wot the garage told me i took it to
wots happening is the car makes a noise like the realese bearing
then when you dip the clutch it goes :confused:
custard
Status: DEFCON Grumpy
Edinburgh
a release bearing is easily replaced as part of a clutch change.no need for a replacement gearbox
Lowtechguy
London
to answer the original question yes it will fit however you have to replace the driveshaft diff cups (these are held in with a spilt pin so you need to hit them out and hit them back in). Alternatively you can use the punto 75 driveshafts with it (they have a larger cv spider than the 55 and 60).
