Technical Gearbox replaement Fiat 500s
LucyJaneParkes
Slough
Hi all, I've been told i need a new gear box on my 2014 fiat 500s! :( being quoted £1700- £1800 with clutch oil etc in the Windsor area!! I'm looking for suggestions on where i can purchase refurbished gearbox other than eBay to see if i can get independent mechanic to do slightly cheaper. Any suggestions? thanks
Model
FIAT 500 S
Year
2014
Mileage
60000
Well i got mine from oldhamfiatgearboxes on e- bay it cost 415 pounds which is about right if you want one thats been rebuilt properly!.
I found them good honest guys to deal with!.
It was fitted by my local independent garage for £350 which equates to about £100 an hour inc vat! all in-including new fluid around £780. so your prices look very high! .
If you choose a garage to do the work at a reasonable price similar to mine, the gearbox can be delivered direct to the garage of your choice and they can arrange the sending of your old one back to oldhamfiatgearboxes as its a exchange deal! .
It all worked out ok for me and could for you to as doing it this way is half the cost of what you have been quoted!".
Those prices do NOT include a new clutch which i absolutely recommend you do at the same time as its a false economy not to you dont want to be taking it apart again in a years time if it was to fail !- these can also be bought from e-bay for around £50 to £80 ,make sure you get a kit that INCLUDES a new release bearing!
As ever chose your sellers carefully check there feedback ratings and look for a 100% and then dig into that feedback to make sure its been earned as a SELLER as some some 100% and when you look at it, it is only as a buyer with no seller rating at all!( BAD FORM E- BAY!) good luck.
What are the symptoms? Manual or automatic?
Be aware the same gearbox is used on lots of different cars with different gear ratios, so you need to be sure any replacement is off a similar car, or it might drive very differently.
If it's a manual gearbox, I'd recommend having a chat with Andy Roberts in Old Windsor.
I've added his details to the garages section here:
