I have punto 75 sx m reg 1200cc. When i put it into 5th gear it is just like neutral there is no 5th gear (it is a 5 speed box).
hope somebody can help.
[V]
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
There are likely to be 2 cables as well, the thinnest of which is probably accidental reverse selection inhibit.
Unfortunately the cheap Porter book I'm looking at doesn't really help much beyond that.. there's not enough detail in the small fuzzy diagrams, or instructions for setting up or adjustment.
I'm still undecided if it was worth the 2 UKP..[:0]
is there any nosie's coming from the gearbox or has it leaked. i blew my gear box and i only blew 1st and reverse gears but the others worked fine. you might have blown a diff. and when you got the car did you not test drive it? you should always go through the gears to check for any whinning nosies you might have a dodgy gear box not uncommon for a fiat!! you can't take it back if you signed a recipet saying sold as seen. plus i think for £25 you could have got the AA out to check it!! would have saved you alot of money before you bought the car. gear box rebuild is expensive if you have blow a diff its a matter of time before the rest of them go
Damn right im good in bed i can sleep for days!!!!
thankyou for all your help.my friend nose a guy that workes with gearboxes.he fixed it for £60.in the car.he took the end plate off the gearbox and used a tool made for punto gearbox
on my punto it would not go into reverse and it was acting like a 6th gear. u basically got a linkiage problem it will cost u about 60 pound to get fixed
