Technical Gearbox Oil, quick Question
Silentbob
Sorry to drop this on you as an emergency, just finished changing the clutch in the Sporting, and (thankfully) remembered that I had dropped the oil out of the box. Need to go get oil tomorrow, need to know oil capacity on a Cinq Sporting (No haynes manual, naughty me)
peaster2k said:
Little off topic i know but how do u change the gearbox oil?
If it's a Sporting, you need to drain it out of the plug under the back of the box near the rear gearbox mount. FWIR, the plug is in the diff housing.
Then when it's drained for a good while, replace the plug, and fill up through the filler/level plug on the front of the gearbox. It's a bit fiddly, due to the proximity of the clutch cable.
HTH
Tosh
I was gonna pop the breather cap off and use that; recalling the last time I replace the oil on my Grale, that took bloody ages :/
Cheers for the info fixitagaintomorrow off to the shop I go (y)
