Gearbox issues car related or bad rebuild?
Ashparker
Hi i have a grande punto jtd... original gear box went after 96k wasn't overly shocked replaced it with a recon with in 6 months it lost 6th contacted the supplier and they replaced it once again within 6 months i have lost 6th.... has anyone had anything like this before we know the boxes on these have issues but surely people are not replacing them every 6 months
I'm assuming you mean the gear teeth were worn away. This would suggest insufficient oil, as 6th is the last to get any with a splash lubricated box. Could also indicate a poor build if the shaft end-float was excessive, or the gears didn't match. Getting them too close together should be impossible, but bearing wear can cause such issues.
It had been installed 6 months before so bearings should be fine n loads of oil this has happened to 2 boxes in under a year no one can figure why
