For info: the stop/start restarting after 25 seconds is because the battery voltage sensors detects the voltage is dropping too far, so it restarts to get the alternator charging it again. That might suggest either the battery is old, or you have something turned on (headlights for example) that is draining the battery. It will also restart if you have climate control and it senses that the temperature inside the car is changing (getting too hot or cooling below the temperature you've selected)
