Technical Gear Shift Selector Lever Weld broken
PirateOZanzibar
2005 Doblo 1.3 multijet
Last night when changing from first to second i lost all gears. Long and short of it appears to be the gear selector lever found under the Gator in the cockpit. Looks like a previous repair weld has broken.
How easy it the gearstick and selector arm to remove so i can get them replaced or re-welded? I cant find a technical manual anywhere online?
TIA
POZ
Thanks for reply but doesnt really help.
I suspect taht i will have to remove the entire gear stick assembly and i am assuming to do that i need to remove steering collumn dah as well as the gear stick dash?
Also do the "ball" part of the gear selector just push into the cables "socket"? i.e. do they just pull out will a bit of effort?
