Technical gear box oil
Suthy 75sx
Reading
hi people,
can anyone tell me how to change gear box oil, or check it for that matter, and how long it will take etc. cheerz
kinedders
Wales in the city, and the village
hi fiat guru here,
Yeah if you look at the bottom half f your gearbox there will be a filler plug (size 12m alan key) put gearbox oil in there and if your checking the level, put your finger in and see if you can feel it or if its slowly dripping out , the level is ok :D :D
rpaterson
Ayr, United Kingdom.
When you're checking the oil level, make sure that the car has been stopped for a wee while otherwise you'll get a false level because some of the oil will still be around the gears. By rights you should add oil until it starts to trickle out. This is because oil will gather at the level/filler plug and you'll think it's fine when it's not.
It should only take about 15 minutes or so to change the oil. Just make sure that the car is on the level when you're refilling it so you get a true indication of the oil level.
