Technical fuel pump wire
The younger modder said:
if your wiring an imobiliser in use the starter motor power lead as the car will be able to run on the fuel in the lines for a bit
True but the car can be push started without the starter motor. If you do this you need to disable the ignition circuit too.
The wire from the inertia switch to the fuel pump is Black with Violet.
arc said:
and that one would be fine to use for the imobliser. i'd heard (not too reliably) that its a brown wire. lucky i didnt start cutting!
Mark, it worked fine on mine, also its easy to hide the relay under the inertia switch cover.
Regards,
Michael
