Yellofrankcar
Can't find the right fuel injectors for my 183 engine (Hitachi GL 212264 - 60594156).
Only the ones for the 188 (M2) engine are readily available (Magneti Marelli Pico IWP 006 - 60657179).
Question: are these interchangeable?
According to the specs there is a difference in the resistance of the coils (12 ohm vs 14 ohm).
I want 1st class (OEM) quality injectors since I've seen enough problems with "cheap" brands (not necessarily barchetta's but in general).
Mine are not giving the desired spray pattern (nicely atomized) and spraying through with cleaner has only partially brought the desired result.
Hope someone has experience with this item (couldn't find anything in older threads)
