I had a days holiday today and thought I would swap the carb over.
I have rebuilt a 28IMB from a collection of carbs using all the best bits.
The carb on Franko was a polish 28SIA with the electronic anti run on valve (that didn't work). Tony supplied me with a valve that worked but I couldn't get the engine to stay running so there must have been a problem with the jet sizes.
I kept having issues at tick over after a run and thought best thing to do was swap it for a standard model.
With everything swapped over which only took 10 minutes, the little bugger would not start. Checked the float bowl - fuel in there!
Poured a little fuel down the carb venture, still wouldn't start. Removed the dizzy cap, points gap looked ok. Cap back on, and hey presto he jumped into life. After a little warming up I adjusted the mixture and idle speed to a reasonable amount and left him running - all ok.
Took him for a little drive and he performed quite nicely with no issues when idling or pulling away.
I pulled up into the garage with the lights on, left him running for a while and then "chug, chug chug" and he stalled.
He wouldn't start again. Checked the fuel filter and there was no fuel coming through. pipe off, turned him over and fuel came out. pipe back on and vroom! Started and ran ok, ticked over, but the fuel is very low in the filter.
Now I have a new pump and the petrol tank cap is free and breathing.
So is this possibly due to the set up of the pump? could it be the thickness of the gaskets are incorrect and causing the pump not to fully operate? any suggestions please?
