Ok, i have just found a new problem, after getting a soaking last night driving through a flood. And its elecrtrical.
Long story short, was driving carefully through a flood , when some knob come flying through the flood in a land rover, covering my car with water. great. Got to my destination and saw the passenger light was misted up, (i use the keep the lights on feature for 1 minute,) and aslo making a whirring noise, followed by a clunk, and this is continous while the headlight is turned on. The passenger headlight also now points pretty much at the floor. On inspection the back cover of the light had come loose in i think if its not shorted, the gush of water seems to have dislodged something and got into the light.
I only had time this morning to strip the battery case and put the back back on before I had to drive to work, and this didnt solve it.
Looking at the threads on here, it seems that this is pretty much fubar'ed as the adujster is jammed and whats causing it is unknown, and no-one seems to have fixed one.
Or have they?
I once replaced the same light bulb on that side, and after replacing it the bulb was in and working but the leveller jammed, so i took the bulb back out and put it back in again and all was ok. The only thing is it was a lot of guesswork as I left the light cluster in situe and stripped out the battery box, but i cut myself and i have aslo made a mess of my wrist this morning. It has been ok since, until now, but it looks like I accidently found a solution for this.
Would it be easier to adjust this if I drop the front bumper and take out the cluster and fiddle with it that way? is there enough length in the loom going to it?
Or have they?
