Hi all,
I have a 2005 Punto 1.2 8v facelift model.
When I bought this car, whenever it was cranked, after the engine would turn over, it would make a cough sound. I assumed this was the starter teeth not catching onto the starter ring on the flywheel properly.
Anyway, there I was on the motorway, when after about 70 mph, the check engine light flashes, and as soon as I slow down, it disappears. I plugged in my OBD device into the car and found the code p0300. There was no other code telling me what specific cylinder had misfired, just that there was random misfire. When the light was flashing, I couldn't notice misfire as the car was running perfectly fine, so I didn't think much of it.
About a week later, I went on the motorway again and the same thing occurred with the flashing light, but as I pulled into my drive and tried cranking the car again, it made a horrible noise as though the flywheel starter ring and starter teeth were grinding against each other and wouldn't start. So I replaced both the starter motor and the flywheel completely.
It was now cranking fine with no cough sound as mentioned before. As I went on the motorway again, I tried keeping my speed low enough to stop the engine light from flashing, but on a slope, I went faster than anticipated. Next morning, when I tried starting the car, there was a very minor cough noise when the engine turned over. Fast forward a couple of days and the starter motor has completely died.
Could it be possible that this misfire issue is affecting the flywheel which effects the starter as the crankshaft is connected to the flywheel. And I am assuming when misfiring, that the crankshaft experiences power strokes from the pistons which it was not designed to do.
A quick note if it will help:
There was a small oil leak at the valve rocker cover, so I had that replaced. Could it be the valves or not enough pressure causing the problem?
Any help is greatly appreciated.
Eddie.
Eddie.
