Technical Fitting stereo unit.
texx
Hi, I've just wired up an aftermarket stereo, no problem there. However does the stereo fit in existing metal bracket or do you take it out and use the supplied bracket that comes with radio. Or dies the new bracket slip inside the existing one. I have a facia panel to fit as well.
Normally you would remove the original cage and fit the one that came with the new unit...However if the cages are the same size I cant see why you couldnt use it..
