fitting cd player into a stilo
headless
I wonder if anyone can help me. I've removed the fiat radio/cassette player from my 04 stilo to fit a new cd player i have bought. All the leads are fitted and connected and it doesn't turn on. Nothing happens at all. I tried another cd player that i had in the house to double check and that was exactly the same. Wouldn't turn on. Is it something simple? Can anybody help please?
Outtta Space
Only the Stilos with factory fitted sat-nav have the switched ignition feed.
You can either add your own switched ignition feed (info in the guides section I think) or alternatively merge the switched/constant power feeds to the constant power feed on the stilo.
If you do the latter you will need to turn the radio on/off manually each time you get out of the car.
jasetheace2178
I am having the same problem not getting any power to the new cd player, but have tested the cables and there is power supplied through the exeisting cables. Does anyone have any advice or experience in this area?
Dont really want to place an ignition feed in.
cheers jase
volxstu
More ICE Please
Kent
Unplug the red wire and plug it into the spare yellow. They should all be in bullet connectors already.
If you need any more Audio help be sure to come over to the ICE section.
