Filler and piant
Filler and piant
Bradford
My rear panel on my sei is really badly damaged and needs a good bita filler in... Then painting over with.
Im getting quotes IRO £250:bang: so im thinking of doing it my self with some fiberglass filler and some paint... is it worth trying with no experience what-so-ever?
worse comes to worse i will have to pay to get it done...
any tips and advice on what to do will be appreciated...
Thank you!
If its £250 worth of damage, it's probably too bad for someone with no experience to make it look any good (unless you are good at that type of thing?) If you try it an it goes pear-shaped, it could end up costing more than the original £250 to get it right.
If you really want to have a bash, make sure you follow all of the instructions, take your time etc (usual advice) have a look on t'internet for some guides?
dont use fiberglass or filler . the idea is get the panel as straight as humanly possible before using any filler.
if you take a picture of the damage i will advise you on how it would be best to pull the dent out. there are several ways in which i remove dents from rear quarters it just depends what sort or location of your dent is.
keep me updated and il do my best to help you mate(y)
Pics are as follows...
As you can tell it is a big job! But i cant afford to have it off the road for over a week while garage does it... im not too bothered about it looking spot on perfect...
a lot of work there bud. If it was me repairing it then i'd put a new rear quarter on it. To be honest that car is a write off :(
as has just been said mate that needs a new rear quarter ideally. its making me wonder what sort of repair that garage are going to carry out for that price and that amount of damage i wouldnt expect anything specatcular and actually if they are just going to fill it i wouldnt waste the money on it.
if i was to repair that i would have to do a new rear quarter coz thats just no good at all mate
they said £250 Fill and spray..both front wing and rear...
they are sayin that with a new quater the have to cut and grind. etc... then paint so i will cost a lot more... does that sound right?
what about the front wing is that easy to do?
Thanks for the advice
Bolts on with a spot of glue / Bolts off. Easy.
I wouldnt repair that. Crush it, it represents something rather dangerous. If youre quoted £250 for all that work thats quite amazing, as Id hazard its much nearer 2-3 times that.
I ment repairing the damage my self.. lol
It is bradford afterall.. alot of competativness in prices...
Cant crush it! just spent close to £500 on the engine!
the quarter panel is spot welded in. To remove, the spot welds need to be drilled out and then the seams where the quarter panel meets its surrounding panels need to be seperated.
The new panel needs trimming to size and put in using flexible adhesive and spot/mig welding. then needs painting.
Quite costly
Hence as well as the wing I think it would be an insurance write off.
The fact that someone would attempt to fill this scares me. The panel has stretched and twisted. Filler should not be used in this way. It will crack out.
so shud i just run it to the ground and leave it as it is...
iv seen the work this guy does and he does work wonders with body work... im just being tight... as a student...
and nothin exciting... Head G and cam and radiator! lol i wish it was exciting...
i wouldnt even drive it mte its a death trap like that. if some1 hits you its over. dont waste the money paying some1 to fill it. all that is doing is hiding the damage temporarily untill the filler falls out.
i wuld strip it and get another shell mate. it would take a new rer quarter and then your looking at a couple of days labour before you have paid parts etc. if you were closer to me i would fit a new quarter for you but to be honest mate you will be throwing good money after bad.
I will have to get a new rear quater put in... cant afford a new car just yet!
spoke to body shop today and they said it will get knocked out filled and sprayed...
im getting ridiculous quotes for the quater panel from scrappies....
buy a new one cinq ones on ebay are cheap so a sinq should be reasonable.
Is less hassle buying new as it doesn't need cutting out and then trimming all the excess off etc.
A couple of days labour to fit a quarter panel seirory? you get 7 hours no matter what car, its being able to repair a fooked panel like that which sorts the girls from the men! anything is repairable and has been! thats why we are called panel beaters not panel fitters, Ant the beater!!
I would be very amazed if you could fit and spray a quarter panel in 7 hours. fit yes would be about 7 hours but 2 days to be painted
