Fiat VP2 NAND repair BOOT LOGO FAIL
Hiddenvision
If you have got here looking for a fix for a VP2 unit that is stuck on the boot logo I may have a fix for you.
Takes about 2 hours. Best for me to do it with the car so I can test everything but if you want to post the unit to me I can attempt to fix so it boots and then you need to finish with a normal SW update via USB.
NO FIX no charge.
Located in SW London.
Hope this helps
Hv.
OP
OP
H
Hiddenvision
Re: Fiat 250 VP2 NAND repair BOOT LOGO FAIL
Ooo,
I just found out that there is more than one VP2 unit.
Someone just asked about a "330 VP2"
So to confirm my post above refers to the "250 VP2" as that is the only radio I have a working dump for.
I guess in time I may find a Working 330 to read but who knows.
Hv.
OP
OP
H
Hiddenvision
Hey Chris
Well the owner of the 330 unit is posting it down so we can give it a go after some looking and testing.
The 250 and 330 units look very similar perhaps it is just the facia that differs, who knows.!
I shall update this once I know for sure.
Hv.
Theres a bunch of these units then also the newer vp2r units fitted to some of the newer models like the tipo
mantasel
NO FIX no charge.
Hope this helps
Hv.
Hi, i need fiat 250 FL VP2 ECE NAV working dump, can You share it? Thanks.
