Technical Fiat Tipo 2017 blown cylinder head
gatillo263
mexico
So i was due on timing belt service and broke while driving, timing belt and water pump replaced but no compression, now cylinder head must be rebuild
as far as i known my car has an 1.4 fire 16v starjet, so i was wondering if its possible to replace it with a cylinder head from any 1.4 fire 16v non-starjet or if i can use pieces from non-starjet engine to rebuild mine
since fiat cars are not broad sold in my country im looking for options
Thank you so much and great forum
Hi all
So I just did the whole thing
I was unable to check piston rings due inaccesible workspace
So attached are some images of process
Was unable to take photos of more because I was working under rain most of time
Finally car is running, it took 3 times to start the engine
Now I have tappet sound because when I removed camshaft housing all of them fell off and now aren’t on their original position
Sound has been getting quieter over time
Now I’m concerned about one thing, if I remove engine fill cover I’m getting some gasoline smell and some gasoline vapor comes from
Is this normal?, it will stop over time?, it has to be something related to intake valves?
Where should I check?
Thank you all and greetings
Here a video of car running
