Peugeot and Citroen use the management system under the Weber-Marelli name.
hence the very common phrase "bloody french electrics!"
they are equally as bad as fiats. now you know why
If I had a dime from every silly git whom I heard ridiculing Fiat, I would never have to work again for my bread. It is quite typical that it is almost always heard from people who never owned a Fiat.
Also, I do not understand the hysteria about Fiat electrics. All troubles I ever had were easily fixed by simple jobs like cleaning connectors etc., as suggested by sumplug.
As far as MM parts are concerned, when I bought my second Uno, it had 195 kkm on the clock and when I changed the spark plugs as a part of its preventive maintenance, I found they were still factory-original MM plugs.
The fact that MM spark plugs were factory-original is... a fact. There was a brown coating on the ceramic insulators protruding outside the engine witnessing their long-term use. Plus, nobody buys MM spark plugs where I live - even authorized Fiat shops are replacing them with whatever brand is offering a sale ATM.
The plugs were factory-original, just like the clutch which needed renewal at 210 000 kkm because of the pressure plate fingers broken.
End of story .
Fiat is not a crap, no matter what germanophiles adoring certain company built upon the order of a certain man with a funny mustache say.
Fiat cars may not be perfect, but they are fine examples of a real value for the money spent.
End of story .
Sounds to me like you do not do regular maintenance on your car. If you did, none of the above would happen. Keep the car serviced properly [ that includes removal of road wheels to check brakes etc], and most problems would not occur.Update for today
-handbrake
FIXED (left side cable and that "lever" on the wheel a bit rusted and stucked - WD40 )
-left rear brake
not working, cylinder gone - stucked and not moving at all after some attempts, but not blocking the wheel
-left rear bearing
not very good sound, probably caused by blocked handbrake and consecutively overheating
-very small oil leak from engine
there's a bit under rocker cover, and hopefully only from there
-lightly cracked that exhaust rubber mounting
I am not complaining, only informing
eec 4 & 5 was reliable in all of its many applications so i dont know why you say that. its widely regarded as a good system in my experience.
Come on guys you cannot say that the problems that Fiats (and other italian cars) are due to improper servicing/maintainence etc, these cars have a reputation for having questionable reliability and their poor residuals bear testament to this. its only now that they are starting to get their act together and make stronger cars...
