Technical Fiat scudo
Raj505
Hi, i have fiat skoudo, the problem is that , u can start the engine drive the car but as soon as u lift the foot from accelerator to press brake the engine is cutt off, and u have to start the engine, i already change crank shaft, furl pump and fuel injector but the proble is still their, even my car is with fiat dealer from last 21 days but they cant fix it,does any one can help me
An obvious, and also possibly stupid question; do you depress the clutch and slip into neutral gear as you stop?
When you start the engine after its cut off-does it tick over ok or do you have to keep revving it to keep it running?
Its not abt changing gear, when u start car its ok, u can start the car but as soon as u leave race engine cut off
