General fiat radio ad185h
Under The Hill
Apologies if this is in the wrong part, but can anyone tell me if it is possible to convert my ad182h to an ad185h ? I had replaced it before I realised that it wasn't the same model. I have still got the old one and wondered if it can be done. Any advice or comments appreciated. Thanks. :) :) :)
hello there,
mine also a AH182 H2. do u able to setup the unit to on/off by using the ignition keys? i have no luck on that. hope u can guide me.
thks.
Not sure if you can convert a 182 to a 185.
To change the on/off settings on an AD185H you press the mute button until you get IGN ON or IGN OFF in the display depending on whether the radio is on or off. Not sure if that will work on a 182.
Try the ICE section if you need further help.
