Technical Fiat Punto ECU Wiring Diagrams
arseofbox
Principality Retained :)
Midlands
I wonder if any of you nice people in this part of the forum could do me a massive favour...
Im looking to put a Punto 1242 into my 899 Cinq, and I understand that I must change the ECU to do this.
I know the Punto 1.1 94-96 has the same model of ECU but a different map to the Cinq.
The 1.2 Punto has a similar ECU (16F as opposed to 6F), and the Cinq changed from the 6F to the 16F in 1995.
Im just wondering if someone with one of the following cars could scan in the circuit diagram for their car's ECU from a haynes manual??
Cars:
Punto 1.1 95 on
Punto 1.2 all models
Arse
Ill think of something witty....just wait and see............wait I might not.
FiatExpert
United Kingdom.
Yes you are right the mapping is different but it will still work. Ecu IAW 6F Does not have key code IAW 16F Does have code system so you would also need these keys
OP
OP
A
arseofbox
Midlands
Yes, I appreciate both of those things- I need a 1242 ECU Wiring Diagram to find out how much wiring I would need to alter\ change.
Also- some people on the Cinq section have no immobilizer on a Sporting (16F ECU), and the Punto 1242 between 1994 and 1996 uses a 6F ECU so a direct swap I think??
'Ang On- so I could even use my 899cc (6F) ECU???? That would make life one hell of a lot easier.....
Arse
FiatExpert
United Kingdom.
If a 16F ecu doesn't have keycode then that because usaully its be decoded and the code ecu ripped off, thus not recoding the fuel ecu and its always virgin.
OP
OP
A
arseofbox
Midlands
But is there anything stopping me from using my 899cc mapped 6F ECU for the conversion?? That'd make life a lot easier as it all wired in as it is....
Arse
OP
OP
A
arseofbox
Midlands
So I could probably do it...but it would need a bit of fooling to make it idle correctly??
Arse
simmy
sheffield
hi im new to the forum so sorry if im butting in a bit
would this work on my punto mk1 its a 1.2 16v sporting and im thinking about putting a 1.4 16v engine in it i no i need the ecu changing would i be better getting it all from the same car the engine came out of ??
Liverpool
No, in your case, it wouldn't.
Tom, I think it'll work just as you propose. Maybe a Tricker/Gazzaman2k chip? I'm pretty sure the 899/1108/1242 pin-outs are the same, but you'll probably need the odd extra wire to work the rev counter (if you want the Sporting one). If all else fails, I've a 1242 v ECU and red key in the battered wreck that was Blue 2 you can have for next to nowt.
