General Fiat Punto 2001 Hatchback
BOYD MM
Q1.I am looking for gearbox oil sump/pan.
Any idea where I can find it?
Q2. Grinding noise on the steering wheel. What could cause this problem?
Hi. Rusty engine sumps is common..they are relatively cheap to buy.. but awkward/ messy to change.
No idea about the g.box question...
The grinding could be the power steering..
Unlikely to be g.box telated.
Charlie
Thanks Charlie.
Where can I find rusty engine sump?
Meaning the power steering motor or the control unit has a problem?
I cant see the origin if the poster / name says not english by nature
So buy gearbox sump / pan is an actual thing
And so is the engine sump / pan
Tbh gearbox hardly ever touched so im voting u meant engine sump
Common as muck to rot out im affraid
Any decent parts supplier should be able to supply one based on vehicle vin
As for steering grinding noise
Could be suspension top mounts been seized to mistaking motor noise
Ziggy
Thanks Ziggy
What I need is a gearbox oil sump/pan.
I changed the front suspension top mount. I am yet to change the rear ones.
Thanks Charlie though Fiatdalys does not have the gearbox sump
Hi, I think this is Fiat part number for the automatic gearbox sump/pan: 9948758
