Fiat Punto 1996 Rear Speakers
INDIKIDD01
READING
Good Morning Everyone,
I Currently Drive A Fiat Punto 1996 1.1 55 And As I Am Sure You Are All Aware The Standard Speakers Are Rubbish, I Have Replaced The Front Dashboard Speakers And Was Wondering If Someone Could Recommend A Good Set Of Speakers I Can Replace The Rear Standard Speakers With
I Am Sadly Not A Car Audio Wizz So I Was Just Hoping To Swap The Old Pair Directly For The New Pair So Please Can Someone Recommend Some Or Tell Me What Size The Standard Speakers Are.
Lee
chaos
Ah. Not good...
Standard Punto rears are 10cm/4 inch
If you really want rear speakers you can uprate them, though I would first try with just the front speakers running, to see if you prefer the sound. If not, then uprate the rears to whatever you fancy :)
Ozzie1989
Doblo Moderator
South Wales
You could try 'Fli Integrator 4' speakers, and the reason I suggest these is that they are 3-way where as many are just 2-way (only bass and hi). As Chaos said, see if you prefer the sound of just the fronts first, expecially if you plan on turning your music up loud or adding a sub if you haven't already got one. Aside from this, see this thread for information on other 10cm/4Inch speakers :)
